N514KP
Sonex-Conventional Gear
Miscellaneous Fuselage Parts
Completed 1ea SNX F15-04 R&L Rudder pedal mount angle, 1ea SNX F15-07R & L Flap drive mount, 1-SNX F15-05 Rudder pedal support angle, 2 SNX F15-08 Spacer plates, 1 ea SNX F15-12 R&L Angle Clip, 2 SNX F15-13 Vertical door catches (phenolic), 2-SNX F15-15 Flap drive pivot block assy's (phenolic), ! SNX F15-03 R RH rudder pedal mount assembly
SNX F15-13 Vent door latches (phenolic)
SNX F15-03R RH Rudder Pedal Mount Assy
SNXF15-15 Flap Drive Pivot Block Assy
Sonex-Conventional Gear Home
1178
509
Instrumentation
Systems
243
