Kurt Haller RV-9A
Date:  10-14-2012
Number of Hours:  3.00
Manual Reference:  9
Brief Description:  Canopy roll bar
Laid out position for canopy roll bar. Drilled the copy deck, then clamped the roll bar in place and match-drilled with long #30 bit. The rear holes turned out to be too close to the roll-bar-attachment weldment joint! Will need to redrill new pilot holes so the full-sized hole for the AN4 bolt encompasses the original milocated pilot holes.
