Kurt Haller RV-9A
Vans RV-9A
Finish
3-2-2013
n/a
Install cbn heat cntl box; laminated Cu bus bar
Installed the heater box. I used nutplates on the cabin side of the f/w. Biotherm sealant applied to the faying surfaces around the hole.
Fabricated a Cu buss bar for the master/starter contactor connection. Used 5 layers of 0.025" Cu sheet, sweat soldered together.
Populating the firewall...
Master contactor/starter relay
Looking into cabin heat control box
Vans RV-9A Home
2839
Canopy (slider)
Cowl
377
Finish
54
231
Flight
815
Panel
Paperwork
965
