Brief Description: First rivets in the top fwd skin!
Riveted the angle pieces that tie the panel to the top forward skin to the top forward skin. I tested with these angles clecoed to the skin and it's flexible enough rivet the center, left and right ribs, as well as the central part of the bulkhead ribs. The long reach, no-hole yoke on the squeezer and back riveting took care of the angles.
In image 2 one can see a hard grommet thru which the 22 AWG wire for the canopy microswitch will go, next to the slot for the roll bar support.
