Installed A/P pitch servo bracket and servo. I did not install the anti-overcenter bracket on the servo--that will have to wait for final assy and rigging. The servo bracket was installed with LP4-3 or -4 pull rivets--laying prone to buck solid rivets would have been very tiring with many snafooey rivits.
Also installed Skyview hub to vertical rib--can see it in pic #1. Pick 3 shows the servo control arm rod end on the elevator bellcrank has been safetied. I read later that Dynon is OK with the nylock nuts alone, even though drilled-head AN3 bolts were supplied. The safety wire was removed later.
(This entry written 7/18/2016 from handwritten notes so quoted hours are accurate.)
