Brief Description: Center brake pedal bracket and bearing block
Drilled F-6118 and F-6115. Drilled out the off-center hole in port-side F-6116. Both F-6116's bolt up fine now. The hole is well and truly ovaled. Will consider replacing the F-719-L when fuse parts are taken apart for deburr, dimple, priming.
Pulled parts for rudder pedals F-6117BPP, F-6117A, F-6117C. Cut the angles for F-6117C's.
Repositioned fuse on a sawhorse at the front so Karl could use the dolly for his motorcycle engine again.
