Kurt Haller RV-9A
Date:  6-4-2012
Number of Hours:  2.10
Manual Reference:  8
Brief Description:  Match drilling fwd fuse angle brackets
Drilled F-721C to canopy deck and panel. Drilled F-721D to the panel only. Marked the holes that will tie F-721D to the canopy decks and will drill the actual holes at the bench. Drilled the center rib F-7108A flange to the firewall. Need to make a strip of Al with holes matched to the top skin to use as a jig to align F-7101A (center subpanel) properly and then drill the F-7108C bracket.
