Brief Description: Drilled rudder pedal bearing blocks to longerons
Drilled UHMW blocks to F-719 aux longerons. Made a drill bushing/template, but the 2nd hole on the port side wandered during drilling. Wound up to close to skin and bolt won't go in easily at all.
Slightly oval might be OK for this hole. A doubler plate with proper hole would work too. But load is the weight of the rudder pedal weldment, borne by the longeron, with comparitively light shear force on the bolts that locate the brackets on either side.
nstalled the blocks and rudder pedals with extra washer and hand-tight nuts on the bolts. (Except for bolt that don't fit!).
Trimmed F-6118 and cut out lightening holes in it. Clamped it and the center UHMW bearing block in place.
