Brief Description: Prime, rivet, drill pivot holes in brake pedals
Finished all deburr and smoothing for holes in BPPs and other brake parts. Used the Jack Dueck EAA Hints for Homebuilders trick of spraying a thin coat of primer and flashing it off with a heat gun (faying surfaces only). Used the Duplicolor SEP for this. Riveted angles to the brake pedals. While the plans called for flush rivets, I mistaken put in uni-heads. The extra topopgraphy won't hurt--might even help center the ball of my feet on the pedals for braking!
Drilled the holes in the brake pedal angle for the AN3 bolts that attach it to the rudder pedal weldment.
