Brief Description: Tools for neglected rear fuse dimples & riveting
Set all the rivets in the longeron and blkhds that could be set while the rear fuse was right-side up. Some of the holes for the last two blkhds at the tail weren't dimpled. Used a combination: the hand squeezer; a c-clamp modified to accept a dimple die shank on the end of its screw; csking a piece of steel to use as a female die, while driving the male dimple die with a rivet gun.
