Brief Description: Mate tail cone and center section
Put a shelf on the dolly table Karl used to mount his motorcycle engine while he was working on it to act as the third sawhorse the plans call for to mate the tail cone and center section. Fitted the main longerons to the upside down tail cone. Lightly clecoed the F-970 skins to the tail cone to be sure the longerons extended to where the firewall will be; this gauged where to cut the notches in the longerons to go around the F-711C emp attach bars all the way at the other end.
With Karl, lifted the center section into place...couldn't slip the tail cone skin in between the center section bottom skin and the baggage floor ribs. Added some clamps to the pieces so nothing would move and went away to puzzle on how the two big sections needed to be cajoled into alignment.
