Brief Description: F-711D angle--one more time; F-6111 aux ribs fit
Remade the F-711D angle on more time. 2nd try was also too short, not enough edge distance for the rivets going thru the aft deck and main longerons. Smoothed up the F-711D edges, backdrilled it to the structure. Deburred the aft deck, spacers, angle, and longerons.
Fit the F-6111 L&R reinforcing ribs to top fuse skin and match-drilled. The "secret" was adjusting the ribs so they fit when the web was flush with the fwd edge of the F-7112 skin. Turned out very little fluting was needed--in fact had to mush out some flutes previously made. Then drilled and clecoed one hole at a time, centering the previously scribed blue line on the rib flange in the CNC-punched skin holes.
