Brief Description: A few fuse rivets; prime steps; rear baggage wall
Working through the aileron pushrod holes, the squeezer was able to put about 10 rivets (each side) in the outboard seat-pan ribs/F-970 exterior skins.
Scotch-brite and MEK prepared the external step weldments for Rustoleum flat gray metal primer. Shot the primer.
Trimmed top baggage rear wall. Laid out and drilled holes, and matched drilled the top to the bottom rear baggage well. Fabricated the seat belt cable wear blocks and associated hardware for the baggage wall.
