Kurt Haller RV-9A
Date:  10-6-2011
Number of Hours:  9.10
Manual Reference:  8
Brief Description:  Aft fuse skin prep / start aft fuse riveting
Drilled static holes in F-773 rear side skins--on the wrong side of the F-908 blkhd! Drilled the holes in the right place and will put in a rivet-to-nowhere to fill the wrong holes. Drilled #8 holes for the Adel clamps that will fix the rudder cable exit bushings in place. Deburred and dimpled F-773s.
Riveted F-712 and -711 blkhds to F-779. Clecoed F-779 to F-778. Clecoed the rest of the aft fuse blkhds (F-706 and higher) to the bottom fuse skins; clecoed J-channels in place.
Was able to squeeze some outside rivets on F-710, -708, -707 near the bottom skin edge.
