Organized the fuselage parts. Big skins against the rear wall of the garage; most of the parts on the wood shelves. Sprayed all of the exposed metal parts of the weldments with Boeshield T9. Sprayed inside the tubes too. Started the firewall. Fabricated the F-601J angles, F-601P spacers, and F-601E stiffener, which went in a little crooked and needs to be re-done. Fabricated the F-601Z fuel pump doubler. Clecoed everything together, drilling the firewall where needed. Still have to drill out most of the holes.
