Put "JB Weld" rivets into the taillight attached plate (4 of the 6 #40 holes)
Sanding tips of horiz stab to 220. Some pinholes exposed where the gel coat wore through. Put some of the JB Weld into the pinholes just to see it it would work.
Tightened the Adel clamps around the polyethylene rudder cable exit tubes. Been on the punch list forever!
Drilled drain holes behind F-711 and F-710.
Vacuumed the rear part of the tail cone real good...restricted access once stabilizers are bolted on.
Bolted vertical fin to the stab and torqued the bolts.
