Brief Description: Prime flap parts; prep right wing top skins
Primed internal flap components with Stewart Systems (nee AFS) white primer/sealer. Prepared right top wing skins and right wing skeleton for riviting top skins: spot primed csk's in main and rear spar, "scarfed" the joint between inboard and outboard top skin. Spot primed the "scaf" joint and sprayed inside top skins w/Boeshield T9. Clecoed the top skins to the rt wing skeleton.
