Put the weatherstripping on the right landing light lens. Can still spend some time to straighten the edges and and fair the curves of the light cutouts.
Adjusted the left wing so the spar was at the same angle at both wing stands. With top skins on, row of holes for bottom skins on the spar are dead straight (checked with a line of taut dental floss.) Checked for twist--none! Made brackets to tie the wing TE to the wing stand posts.
Drilled out the rivets holding the nutplates for the inboard z-bracket. Drilled out the rivets holding the nutplates on the outboard z-brackets. Scraped a few more blobs of Pro-Seal off the inside of the tank skin I missed last time. Set the tank in place and drove in the screws every 4-5 holes. Drove all screws into the joint plate. Used the 0.2040 reamer to size the z-bracket holes for the 1X oversize bolts.
Checked the flap bracket alignment with the floss line--AOK both left and right wings.
