Finished the flap angle fab to the point where they could be drilled to the spars and inboard ribs for both L and R flaps. Used 2 spacer plates (one to simulate the flange of the nose rib in the final assy) under the angle bracket so the holes drilled thru it with the side bracket will be located correctly. Drilled all the holes that needed #30, including the pattern in the inboard rib. Drilled and reamed to 0.249" the hole where the flap rod-end bearing goes.
