Took apart clecoed aileron parts that need priming (nose ribs, reinforcing plate, ribs, spars: sanded, scotch-brite-wheeled all edges. Will prime these with the stiffeners at the same time, even though not all the holes are drilled out. Otherwise, setting up the spray rig just for the stiffeners is a waste. Will spot prime areas that need it before final assy.
