Brief Description: Shop rearrangement / wing stand
Took all the wood down from the wood rack. All of the long pieces of the wing kit (rear spars, fuse main longerons, etc.) will fit on the very top. Ribs stack on the shelf below, and the miscellaneous parts go there too. I put the main wing skins in the back of the plywood rack, except for the tank and LE skins (for wings, flaps, ailerons) which went under the workbench on the right wall with the wing tips.
Had an old bedframe in the rafters. Bought some perforated, galvanized steel angle from Home Depot. Started cutting and grinding the angle to make four stanchions for the wing stands. I'm making 4 to build both wings at the same time. The wings run back to front of the garage, with the ends almost to the door. With stanchions, the garage door can still open.
