Kurt Haller RV-9A
Date:  5-19-2007
Number of Hours:  6.50
Manual Reference:  7
Brief Description:  Right tank/LE. Re-do left W-919
Dimpled #40 holes with tank dies, right hand tank skin.
Disassembled r.h. LE. Used the W919R from right as a template to drill skin-jointplate-rib bottom holes in a new W919L jointplate for the left LE. Reassembled the left LE and set new W919L in place to drill the top #40 holes. Then clecoed the two halves of the first W919R plate to the new one to match drill the holes for the #8 screws. Deburred and dimpled the #8 screw holes.
Clecoed K1100-08 platenuts to both W919's and drilled the #40 holes to attached them. Deburred and dimpled the holes.
Deburred the right LE skin and ribs. Took of the right LE skin plastic and dimpled skin and ribs.
