Fabbed the T-905 attach brackets for both tanks, and 4 T-410 reinforcement plates (2 for each tank). Drilled the left tank's T-905 and T-410 parts to the end ribs.
Put platenuts onto the left tank capacitive fuel sender plates. Modified the vent tube grommets for cap sender wires. Cut vent tube to length and inserted the left vent tube. Trial fit the cap plates.
Cut the big hole in the left tank inboard rib and drilled the holes for the T-408 access plate and T-407 reinforcement ring.
