Brief Description: Left wind skins and left leading edge
Finished drilling the top and the bottom skins. Cut the J-channel stiffeners and drilled them to the top skin. Made the cradle for the leading edge and fabbed the left leading edge. Fitted and drilled it to the spar.
Fabbed the W-919 joint plate and drilled it. Didn't like the fit very much, so a cut it into two sections, top and bottom. Will add a small plate to reconnect the two main sections of W-919 later.
