Brief Description: Wing root fairings; tank attach brackets
Hours worked 2-Sep and 4-Sep-2017
Completed fabrication of "breakaway" tank attach brackets. Over bent one of them, and riveted a 1/8" spacer to it to make up the gaposis.
Marked out the belly skin to wing root bottom skin pre-punched holes. Applied the wing root fairings, drilling and clecoing #30 to start. Eventually, dimpled 8-32 screws will attached these metal fairings.
Broke the TXPNDR antenna rolling the shop vac from one side of the fuse to the other...dumb!
Left root fairing
Left root fairing, again, for no particular reason
