Sanded Superfil on tops and ends of elevator tips and rudder tip w/palm sander, 120 grit. Formed new foam inserts for the HS tips. Mixed up 1 squirt's worth of epoxy and glued foam into HS tips and put one layer of 4.5 oz cloth on the VS tip foam block. Laid a strip of peel ply on top and set aside.
