Filled in the clecoes on the bottom of the nose skins to every other hole. Clecoed the top of the nose skins with the usual amount of grunting and swearing. Had to file the butt edges where the inboard and outboard skins met--fit very nicely now. Per instructions, drilled the trailing edge wedge to the table, then drilled the nose-skin to nose-rib holes. Need to drill all skin to spar holes and top skin to rib holes now.
