Completed the left wing landing light lens. Was a bit to forceful on one of the top holes: two small diametrically opposed cracks. Stop drilled and proceeded to enlarge the holes and countersink them. Both the cracked hole and the one next to it have tiny cracks radiating from the edge into the countersunk surface.
Was low 60's F today, high 60's yesterday. Warming up the plexi with a lamp may produce more stress than soften? It's easy enough to make a new lens so I'll install this one and see how the cracks propagate. They're on the topside so will be easy to spot.
Put the weather stripping around the left lens. Need to do the right one still. The lamp+reflector assys were put into the brackets, and all screws snugged down. Hooked up the battery charger to one light to check it out.
