Cut one flange off the brackets to shorten them to fit the -9A wing. Smoothed, drilled, deburred and dimpled. Riveted the flange to the bracket.
Used the template (spray glued to 1/8" ply) to locate and drill #40 holes in the wing ribs to mount the brackets. Had to cut the template down to get it through the lens opening in the wing.
