Brief Description: Misc rivets and rolled rudder leading edge
Finished root and tip rivets on elevators and rudders. Used two MK-319-BS pull rivets for the last hole in the rudder tip rib. Also used one OSH pull rivet on the tib rib to rudder spar (the other pull rivet is regular issue from Van's.) Rolled rudder L.E. Drilled, deburred holes and pull riveted. Screwed the rudder rod-end bearings to proper depth--did not torque them into place.
