Installed rudder counterweight and torqued the bolts to 30 in-lb (nylok provides resistance of ~ 5 in-lb and spec for AN3 (10-32) bolts is 25 in-lb). Riveted tip on, enclosing the counterweight. Riveted root rib. Fit the rudder bottom FG peice and drilled (#30) mounting holes.
