Kurt Haller RV-9A
Date: 11-24-2006
Number of Hours: 6.00
Manual Reference: 6-4,5
Brief Description: Vertical stabilizer
Washed, etched, primed all VS parts. Riveted VS rear spar, doubler plate, brackets. Riveted the 5 members of the VS skeleton together. There were only 4 scratched areas on the inside of the VS skin, so I sanded/scotch-brited these areas, wiped with MEK, then spot brushed primed. Modified the HS cradles for the VS skin. Set the skin in the cradle, the skeleton in the skin, and clecoed it together.
