Riveted nose ribs to left and right HS skins. Used rivet squeezer on end ribs and buck riveted the center nose rib. Skins were stood in the jig to do this.
Riveted the #2 and #4 ribs to the fron HS spar, squeeziing the 1/8" rivets. Droped the spar into the right-hand skin and clecoed it up. Added the #1, #3, ribs. Riveted outboard nose rib with squeezed AN470AD-4 rivets. Used blind rivets for the #3 rib, which reaches thru the spar to the middle nose rib. Buck riveted the outboard spar to the skin (between #4 rib and outboard end), then fitted #5 rib, squeeze riveted the rib to the spar, then squeeze riveted the #5 rib to the skin.
