Brief Description: Disassembled wing skeletons, prep for primer
Disassembled wing skeletons. Made a template to drill a hole in a consistent location in all wing ribs for electrical conduit. Enlarged holes to 3/4" with unibit. Smoothed edges of the holes with Scotchbrite.
Deburred, dimpled the rear spars. Csk the dimples a bit more by hand with the 100 deg deburring bit. Just enough for a skin dimple to set in better, as specified in the instructions. Csk both wing spars for nutplates where the inboard tank z-brackets will be bolted to the spar web.
