Finished fitting the tank ribs to the skin. Prepared the z-brackets per the plans and temporarily attached the rear tank baffle and brackets with AACQ4-4 rivets. Fit the tank to the wing, clecoed, and match drilled z-brackets and the W919 joint plate.
Used Smart Tool to set each end of the spar to the same angle on the stands. Plumbline test of the wing twist was good.
Removed tank from the wing. Match drilled the skin-to-rear baffle rivet holes then csnk the holes.
Engraved the z-brackets with their positions, and removed the temp rivets. Drilled the z-brackets for K1000-3 nutplates.
