Kurt Haller RV-9A
Vans RV-9A
Horizontal stab
Bandsawed out the HS cradle blocks. Screwed to 2x4 stock to be able to clamp them across the workbench. Began assembling the right HS. There is a huge gap between the inboard nose rib and the spar--I forget to put the front spar doubler on the spar!
Right HS clecoed together
End view--straight thru the holes
Yes, I'm building this sucker
Vans RV-9A Home
2839
Canopy (slider)
Cowl
377
Finish
54
231
Flight
815
Panel
Paperwork
965
