--Battery was still not >12,9 V after resting overnight. Put it back on charge and flipped the master on to start up Dynon SV system. Warning that Dynon b/u battery was still low was issued. By the time I left, b/u battery was in "standby" mode at 11.58V, and the PC680 Battery Minder had tripped into "maintenance" mode. Battery taken off charge. Will check OC voltage next time at hangar.
--Updated Dynon s/w to 15.3 and current chart data
--Affixed current ELT registration sticker NOAA kindly provided to the panel next to the ELT buttons above the glove box.
--Affixed placard above SV-1000 display with on/off, reboot, and setup buttonolgy.
--Placard for fuse box did not correspond to installed fuses and was too wide. Checked dwg 9000 and it's fuse values match installed values. Redrew the fuse placard (at home, later) and updated dwg 9003.
--Installed velcro buttons on the slider bow for Koger sunshade
