Kurt Haller RV-9A
Date:  7-21-2018
Number of Hours:  6.00
Brief Description:  Cowl, main cotters, flow test line
Sanded cowling's "nose job' and hinge pin covers. Shot them with rattle-can sandable primer, still wet in image 1, all flashed off in image 2.
Bought h/w store 1/8x2 cotterpins for the main gear and installed them. Also bought 10' of 5/16 chain--CHP approved for vehicle tie down--and shackle hooks for anchoring the plane for 1st engine start.
Speaking of first engine start, full flight quote from Gallagher was just over $1k--not bad! But I need to complete the BFR and get 2 hrs in type before acting as PIC...so 1st engine start will take a bit of time. There's another transition CFI in Oregon besides Mike Seager so I hope booking a time isn't too far out.
Finally, disconnected the main fuel line at the entrance to the engine fuel pump. Rigged up and elbow and a length of 3/3 Al line at the same AGL as the pump inlet. I'll attach a grounding wire to the Al tube that will dangle in the gas cans catching the gas going overboard when flushing the lines and testing flow rates.
Primed the nose job
Primed the nose job
Primed cowl hinge pin covers
Fuel flow test line
Fuel flow test line
