Brief Description: Cowl nose job; alt safety; cockpit placards
1. Cut the nose off the upper cowl. Made a one-sided sanding stick, glued 80-grit to it, and created a uniform 1/4" gap referenced to the rear spinner bulkhead (image 1).
2. Safetied bolt heads on alternator bracket and the tie between the alternator pivot bolt and the starter motor lug. (images 2 and 3),
3. Made three labels for the cockpit--see next entry for pics.
