Brief Description: Thin seat, data plate, Reg/AWC pocket, tips, harne
--Thin seat cushion for _el pilot gigante_ recieved and tested--all good.
--Data plate was engraved by a local tropjhy shop--installed on left fuse below the stab.
--Installed a 4x6" clear plastic pocket to left cockpit wall (see image 3) with 2-sided carpet tape. Slipped the registration form 8050-3 into it. Special AWC goes there soon....
--Laid up 3" wide, 9-oz fiberglas strips on the insides of the wingtips to solidly lock the top and bottom halves together again. (The small strip applied to the outside of the joint will be mostly gone after reshaping the seam.)
--Started installing Crow harnesses ordered through Flightline Interiors.
