Duct taped the wingtips to hold the slit seam closed, then laid up 1" strips of 'glas to "tack" the tips closed. A structural joint will be laid up on the inside. The glass on the outside will either be sanded away or filled,
Cut 0.090" dia stainless steel rod for the seat back hinges (on the bottom as well as the back rest).
