Kurt Haller RV-9A
Date:  9-16-2017
Number of Hours:  3.80
Brief Description:  Small jobs
Smoothed edges of tank brackets.
Wing root fairings drilled #19 and dimpled for 8-32 flat head screws.
Underside holes for the belly skin to wing root bottom skins drilled #19.
Measured final lengths for tank vent tubing coming out of the fuselage and cut to length. Out of the right size AN fittings, so flaring and final fit up have to wait.
Ordered new txpndr antenna and longer AN4H-xA bolt for the tank brack I needed to add a spacer to due to overbending.
