Kurt Haller RV-9A
Date:  10-9-2016
Number of Hours:  5.00
Brief Description:  Cowl fill; PFD/EFIS removal; spare EMS leads
Labeled spare EMS leads. Routed them through corrugated conduit down left side. Will secure them under left side main gear bracket.
Uninstalled and reinstalled the D1000 and D700 displays without reaching through the (as yet uninstalled) glareshield. The D700 comes out first, then D1000. Replacement reverse of removal. There's juuuuuust enough service loop to reconnect the D37 connector to the D7000.
Washed the exterior of the cowls with Dawn and water, then set out to dry in full sunlight before doing the electrical stuff. Cowling completely dry when done. Mixed up white tinted epoxy and brushed onto the cowling full strength.
Bottom cowl, 1st epoxy coat drying
Ditto.  Flash on.
Ditto. Flash on.
Ditto squared.  Other side
