Drilled a 3/8" hole in F-705 on the pilots side near the top. ELT's remote operation cable and 1/4" poly tube to the ALT STATIC switch on the panel routed through it. Cable and tubing put through white corrugated conduit and run under the pilot-side canopy deck.
(This entry written 7/18/2016 from handwritten notes. Quoted hours are accurate.)
