Brief Description: Forest of tabs ground block, homemade.
Spent too much time documenting a roll my own forest-of-tabs ground block (see pic 1) and then fabricated it. The 1/4" fast-on tabs (8 per assy, 32 tabs altogether) were sweat-soldered to the brass sheet with a propane torch. The large hole is for the brass bolt that will be the common ground point for the battery negative terminal and braided straps going to the engine block, The smaller hole is to secure the assy to the firewall.
