Brief Description: Elevator trim servo motor wiring
Used "naked" Dsub pins to connect the elevator trim pigtail wires to 5-conductor shielded cable. Each wire got their own piece of heat shrink, then larger hunks of heat shrink went on over the lot. Tied the bundle down with lacing cord at two points so the cable could exit out of the elevator spar. Attached two of the little plastic tie-down thingies to the cover plate and edge of the servo motor.
