Kurt Haller RV-9A
Date:  3-18-2013
Number of Hours:  6.00
Manual Reference:  8
Brief Description:  Finished turtledeck riveting and misc jobs
- Finished turtle-deck skin rivets.
- Screwed rear sliding canopy rail into place. Torqued the all-thread rod to the F-906 blkhd.
- Put the shell on the airleron trim servo's DB9 connector. Cut the elevator trim servo motor cable (I hope) leaving plenty to connect it up to the panel. Put a DB9 connector on one end of the cut cable for the aileron servo motor. Seems to be enough to connect it up too.
- Tied up the static line "permanently" with the lacing cord
- Pop-riveted the little brackets for the panel air vents to the fuse side skins
