Brief Description: Engine mount final match drill to f/w
Drilled engine mount holes out to final size, using the mount as a guide for match-drilling. Drilled 1" hole in f/w to allow for nose gear taper pin installation. Used a hole saw with lots of cutting lube and low speed. Didn't turn out too bad.
