Kurt Haller RV-9A
Date:  11-2-2012
Number of Hours:  3.00
Manual Reference:  10
Brief Description:  Nose/main gear leg weldments; rudder links
Installed and torqued the weldment to the nose gear that limits the free-castering swing of the wheel. Installed and torqued the main gear brake bracket weldments.
Attached the rudder cable links to the pedals. The ferrule of the clevis at the end of the cable fouls on the grommet in F-902. I think I can bend the links slightly so the ferrule passes through w/out interference.
