Brief Description: Canopy rails on fuse sides and turtledeck.
- Set canopy rails in place, aligned 'em parallel, drilled fwd-most holes, then aft-most holes. - Fabricated the slider rail that guides the rear of the canopy. - Drilled the slider rail to the fuse. I probably should have waited, because it turns out moving the rail fore and aft will tune the height of the canopy wrt the lip of the turtledeck skin. I'll have to figure out another way to set the height...new plastic slide block, perhaps?
- Checked the silica gel in the engine box. Everything dry.
